Slicing a solid to laser cut
I used 123d Make to slice different solids, so I can cut them with a laser. Now, I am using Fusion 360, but I cannot find the way to achieve the same slices. Could you please point me in the right direction?
eellenburg
Right click on the solid body in the tree and save as STL. Import into 123d Make to slice.
HughesTooling
Don't know if this method will do.
Mark
Mark Hughes
Owner, Hughes Tooling
