Slicer for Fusion 360
Hi All,
I have been using Slicer for Fusion 360 and have not been able to get the 'slot offset' function to work - whenever I enter measurements it only decreases the slot size - which makes it impossible to assemble the final model. The only workaround I have been able to find is by increasing the material thickness in the Slicer program to 'trick' the software into thinking the material is thicker and giving a larger slot size. Is there an alternative to this? How is the 'Slot offset" tool intended to be used?
Cheers,
Erin
MoshiurRashid
It is a common problem that some people (including me)It is a common problem that some people (including me) is facing. I'm waiting for the developers to solve this issue.
https://forums.autodesk.com/t5/fusion-360-design-validate/slicer-for-fusion-360-slot-offset-wrong-di...
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
