How can i exprot the skecth in pdf file?
I know it is possible to export in DXF, but i want the dimention also in the same file, and with pdf file it will be easy to open from a simple pdf viewer.
g-andresen
Extrude a body of any height from the sketch and create a drawing using "Drawing from design".
In drawing mode, the desired view with dimensions has to be generated and choose PDF output.
günther
wmhazzard
Sketches can not be directly saved as a PDF and only show up as dashed lines in 2d drawings, maybe someday it will change.
i think it will be a useful feature to export as pdf.
Fusion team please add this feature.
