Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Slicer for fusion 360 outputs incorrect dimensions.
5 REPLIES 5
846 Views, 5 Replies
Hello everyone,
I have been trying to get this apple pie ready for laser cutting out of plywood:
My original modelMy original model
I used the slicer for Fusion 360 on it:
The model sliced upThe model sliced up
I got my sheets out of it (which are quite inneficient in material usage by the way. The first sheet has a ring in which another circle could easily fit...):
The sheetsThe sheets
I saved them all into this folder:
The opened folder with all layersThe opened folder with all layers
I check one of the dxf files:
One of the DXF files, with incorrect dimensions...One of the DXF files, with incorrect dimensions...
In this dxf I measured the center circle. Although it is not supposed to be exactly the 22 mm it was in my stl file (the measurement tool doesn't let me select it as an actual circle), I am sure that 555 mm for a 22 mm hole is a bit excessive :P. Does anyone have an idea as to why this huge inaccuracy occurs? In the first screenshot you can see that the width of the entire part is not even as big as 555 mm.
Any help would be greatly appreciated!
Ruben
Hello everyone,
Ruben
5 REPLIES 5
Looks like you're off by a factor of 25.4? That just seems like a unit conversion issue to me. Check that you have the correct units set when you open the dxf file.
Yeah,  by now I figured it out myself. It was indeed a problem with imperial units, even though the slicer for fusion 360 program indicated the drawings were metric.
rosch100
rosch100
Observer
Observer
I cannot find the slicer in the appstore - help!
g-andresen
in reply to: rosch100
g-andresen
it´s no longer supported
Info
günther
Info
günther
etfrench
etfrench
Slicing a model is easy.
  1. Create a sketch.
  2. Draw a horizontal (or vertical) line wider or longer than the model.
  3. Rectangular pattern the line.
  4. Close Sketch.
  5. Open Split Body command.
  6. Select all of the lines for the Splitting Tool(s).
ETFrench
  1. Create a sketch.
  4. Close Sketch.
ETFrench
