Sketching symmetric splines
I'm basically trying to sketch a single spline line that will be symmetric according to a line of a point.
How would I do that?
Thanks for helping.
g-andresen
1. Create a mirror line in the position you want.
2. Use the mirror command  > object  and mirror line !
günther
Yes but then it doesn't make it continues causing a little blimp in the
middle.
g-andresen
can you upload a screenshot to show the problem?
günther
Yes here:
I'm trying to draw a symmetric spline from point to point while the centre is that small line in the middle.
TrippyLighting
You can mirror a spline, but have to apply at least a horizontal constraint to the center tangent handle.
Here's another way using a single spline.
