Sketching on a curved surface?
mail8YLTP
mail8YLTP
I have looked at several posts regarding this subject but cannot seem to find one to suit my problem. I want to map the sketch I have created in my picture to the suface of the object and then move it about and edit the nodes. When edited I then wish to cut the sketch profile from the object. Is this possible in Fusion360?
Accepted solutions (3)
g-andresen
Try: Solid > Create > Emboss
günther
TheCADWhisperer
@mail8YLTP
What are you attempting to mode - do you have a picture of something from the real world that is similar to your Design Intent?
mail8YLTP
Yep thank you for this. I must be losing the plot as I have used this before but only for text.
johnsonshiue
Hi! There are multiple ways to do this. You may create a new sketch and use Project to Surface command to project the two curve to the selected face (Intersect will work too). Or you may extrude the profile as a surface body and then trim off unwanted portion.
Many thanks!
Software Test Engineer
