Hide fillet in drawing but keep in 3D model.
pulkit.goyalUT2C5
pulkit.goyalUT2C5
I do not want to show fillet edge in my drawing as it messes up with the dimensions instead will mark up the edges where fillet needs to be, with a Leader Note, but want to show it in the 3D file, which I will share with the CNC guy.
How can I do this?
Dimension highlighted in yellow needs to be 32mm but because of the fillet it became 32.71mm. I want the machinist to know that it needs to be 32mm and then do the round edge. But Because of the fillet edge displayed here, I am not being able to.
Is there any solution for this?
bwalker145
I don't think it's possible to do exactly what you're asking. Two possible workarounds:
a) Use the "Edge Extension" in the drawing to create a sharp point to dimension from (this is what I do):
b) Leave the edges sharp in the model, and just add a radius note in the drawing.
pulkit.goyalUT2C5
Thank you so much😀. Edge extension was such an easy way. Now I am thinking how I missed this. 😅
