Sketching on a curved face
12 REPLIES 12
Message 1 of 13
dallasN79PV
639 Views, 12 Replies
Hi
Im trying to shop draw a curved balustrade. I need to add the posts at a certain dimension, measured on the circumference not in a straight line (I laid tape on the inside of the curve, marked the position of the posts, then laid the tape out flat and measured the dimension).
I cant find a way to draw a line on the face of the curve or offset a line on the face of the curve.
How would you suggest I do this?
Thanks in advance for your help.
12 REPLIES 12
Message 2 of 13
davebYYPCU
in reply to: dallasN79PV
Let Fusion work it out.
Create > Pattern on a Path.
Use spacing and count.
Might help....
Message 3 of 13
jhackney1972
If you need a demo or further help with your design issue, attach your model.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
Message 4 of 13
dallasN79PV
in reply to: jhackney1972
Thanks for your help mate
Message 5 of 13
jhackney1972
@davebYYPCU has already mention the solution, my video will just demonstrate the process and some of the options.
Message 6 of 13
davebYYPCU
You should make a centre line path from 1st body for how far?, then you can set the Pattern without drama.
Might help...
Message 7 of 13
dallasN79PV
in reply to: davebYYPCU
Thank you so much John!
I was trying to do it in a sketch, I didnt even consider using pattern on a path.
Much appreciated mate
Message 8 of 13
dallasN79PV
Thanks for your help Dave
Message 9 of 13
dallasN79PV
This method has worked perfectly for me, however I have one last question...
The posts are not vertical, some of them have a 3-4mm lean from top to bottom, how would you suggest I lean the post once I have set them out using pattern on a path.
Thanks in advance.
Message 10 of 13
davebYYPCU
You didn't say which way they lean.
That will complicate things, until we know the details.
Patten on Path is not available as a sketch tool, so more detail will be required.  Circular pattern comes to mind.
Might help....
Message 11 of 13
g-andresen
maybe this is what you want to achieve
günther
Message 12 of 13
davebYYPCU
in reply to: g-andresen
If all are leaning the same amount, you would do the first, and the Pattern on a Path would still do the job, - so there must be more to deal with.
Might help....
Message 13 of 13
g-andresen
Might help....
take a look at # 9:
... some of them have a 3-4mm lean from top to bottom...
günther
