Sketching a Circle - inconsistant lines displayed
kevinwatts
kevinwatts
Sketch Problem: in a complex model it became difficult to determine which point was correctly intersecting with which line? Using the circle to define the center intersection of bolt holes it looks like the circle is wrong. I found one center error in a design: of four mounting holes one was out by Z= -0.0008" which may not seem like much but it should not happen. Why should a flat 2D dimensioned circle display two perimeter lines.
Work Space: On default Origin Plane, 8" Circle drawn from center point with construction line drawn and then dimensioned 4: from horizontal centerline.
kevinwatts
Work Space: On default Origin Plane, 8" Circle drawn from center point with construction line drawn and then dimensioned 4: from horizontal centerline.Work Space: On default Origin Plane, 8" Circle drawn from center point with construction line drawn and then dimensioned 4: from horizontal centerline.Center Axis - Construction Axis lines and Circle center point (8" dia.)Center Axis - Construction Axis lines and Circle center point (8" dia.)Now Zoom in on top Circle, Construction Line and Grid intersection.Now Zoom in on top Circle, Construction Line and Grid intersection.Magnified View: Both Construction Line and Circle are set as "construction lines" (dashes).Magnified View: Both Construction Line and Circle are set as "construction lines" (dashes).Magnified View:  Construction Line and Circle outline set to "Normal" & hovering over circle. Notice the three lines that become visible.Magnified View: Construction Line and Circle outline set to "Normal" & hovering over circle. Notice the three lines that become visible.
