Lines in wood grain rendering, not sure of cause?
Sometimes when I'm rendering I get these close lines that appear, they look like part of the grain, but they don't show up in similar renderings.  Any idea what is going on?
Correct versionCorrect versionLines showing up?Lines showing up?
I_Forge_KC
Is it a different lighting style? It almost looks like the reflection of the grid light (or something similar) shining back by the gloss of the wood finish (what gloss there is).
K. Cornett
Generative Design Consultant / Trainer
Don't think so. The only difference I can figure is it was rendered on different PC's, but it's the same file.  I've tried moving the light around and redoing the material but it always stays with the lines.
I_Forge_KC
If you change to something like gloss plastic what does it look like?
K. Cornett
For some reason, when I duplicate the walnut material, then re-add it to all the parts, it seems to fix it?  I adjusted no settings after duplicating.
