Sketch will not extrude as I expected
FacebookGroupMember
FacebookGroupMember
I have drawn out two separate squares side by side and dimensioned them. I even added the dimension from the base line to the left square but when I come to extrude them into my body the error box says they aren’t joined so this is why only the one on the original line works.
Please advise
FacebookGroupMember
I'm not sure I understand the issue you're having 🤔
FacebookGroupMember
Emanuele Pinton the two squares aren’t linked together so when I extrude through the body and pick them only the left square goes through and not the right square.
FacebookGroupMember
Mark Sneyd is the square cut on the right caused by another operation?
FacebookGroupMember
Emanuele Pinton that was originally extruded when my squared weren’t constrained so I wonder whether that’s why it’s now not working 🤔
FacebookGroupMember
Emanuele Pinton that was it, thanks for your suggestions
FacebookGroupMember
I didn't do anything but Im glad you solved the issue 😛
