Fill hollow body from STEP file
martinadDKD98
Message 1 of 8
martinadDKD98
Hi all,
I downloaded a STEP file from GrabCAD which contains the boom of an excavator. The boom is a hollow body, as can be seen in the following section analysis:
Boom (section analysis)Boom (section analysis)
How can I fill this body to make it solid?
What I did so far: I used different section views and the tool "Press/Pull" in order to pull the internal surfaces. This works, but seems wrong/clumsy to me, because I have to use different section views, and I have to guess when I pulled enough. This feels more like painting than constructing.
Is there a better way to fill this hollow body?
Martin
Replies (7)
Message 2 of 8
TheCADWhisperer
Boundary Fill
Message 3 of 8
martinadDKD98
I already tried boundary fill, but was not successful (because I am new to Fusion 360).
How do you do that with boundary fill? What would be the "tools" and what the "cells"?
Message 4 of 8
TheCADWhisperer
See Attached.
Message 5 of 8
martinadDKD98
Thank you. My fault was, that I did not select the "Boom Pin".
Message 6 of 8
dikshant.
Tools are the bodies or components you wish to use boundary fill on and cells are sections of the body/component you wish to keep after the boundary fill.
Message 7 of 8
Ajay_Kumar_Reddy
Hey @martinadDKD98 ,
Adding to @TheCADWhisperer you can also try in this way. Just delete the tapered faces on both sides and use extrude to pull the face. see the attached file.
Message 8 of 8
martinadDKD98
@Ajay_Kumar_ReddyThis is an interesting behavior. I did not expect that Fusion would react like that, when the tapered faces are deleted (converting the whole inside into one single, straight surface).
Thank you.
