Sketch text in Drawings
Lonnie.Cady
Advisor Advisor
Lonnie.Cady
In the drawing environment when I choose to show a sketch the sketch lines show up but the sketch text does not display, is this by design or a bug?
I can explode the text and then is shows up but then can no longer be edited in the model environment.
g-andresen
just extrude the text in your design.
günther
jhackney1972
@g-andresen @ has given you the answer, I just wanted to add that you should use Thin Extrude with a very small height and wall thickness and select your text with a window for speed.
John Hackney, Retired
