How to create large threads with low thread hight
cyucelEJ2QP
cyucelEJ2QP
I've got two hollow cylinders of 42mm diameter and 0.8mm wall thickness (the whole thing to be 3D printed). I'd like to have one cylinder to screw into the other, forming a continuous tube.
I create cylinders and apply threads to them, but I am not sure how can I make individual threads less high without making inter thread distance smaller. Perhaps attachments will explain this better.
If you please look at the cross section I shared, the problem I've got is that the wall thickness is too high (2.5mm), however to lower the wall thickness need to make individual screw threads smaller, but I don't want to change the distance between threads.
If I change thread designation to M3x1.5, then I get the threads of the size I want but then I get them too close to be printed nicely.
Hope this all made sense.
MRWakefield
It sounds like you need a thread that's either 'stretched' or is truncated on the crest and root. For the stretched option you'll need a thread with a much greater flank angle than the standard Metric form. For the truncated option you'll need to add or subtract some amount from the crest and root values accordingly. For both of these options you'll need to create a new custom thread file. You'll find many posts about this if you search the forum.
You could also create the thread using the 'Coil' command, again, you'll find posts about this method on the forum.
If you could upload your f3d file that would help us to come up with a solution.
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
cyucelEJ2QP
Thanks for the answer, f3d attached.
MRWakefield
I've attached an edited version as well as a custom thread file I've created. I've increased the flank angle to 80° (same as the DIN 40430 PG thread) with a pitch of 3mm and a thread depth similar to a standard metric 1.5mm pitch thread.
You'll need to copy the thread file to the Fusion 360 threads folder. This is easier said than done as this folder often moves when Fusion is updated. To make things a lot easier I'd recommend the 'ThreadKeeper' add-in to manage your custom thread files.
Hope this helps.
Marcus Wakefield
