Do I see white dots? (Not good!)
Do I see blue lines? (Not good!)
Do I see asymmetry where I would expect to see aesthetically pleasing symmetry?
pretty sure this is a profile tracking bug. I think it's related to the arc here-
@jeff_strater , @Phil.E -wasn't there something like this reported a little while back?
@laughingcreek wrote:@jeff_strater , @Phil.E -wasn't there something like this reported a little while back?
What is the diameter of your circle?
Is there a logical reason that it is not dimensioned?
Why do you have this extra line in this side, but in no other locations (except the double mirror)?
Are there any unresolved issues highlighted in yellow in your Timeline?
I am trying to determine if the Design Intent is for symmetry about this line?
Many of your sketches are not fully defined which makes it difficult for me to determine your true Design Intent.
I suspect that this geometry would be more efficiently created with a Pattern, Rib or Web.
The circle repeats the diameter of the "gore".
Lines were drawn on the circle in the form of a curved grid. Then the extra lines were cut off.
The protruding lines could not be cut off.
@kroteg304 wrote:The protruding lines could not be cut off.
You should fully constrain each and every sketch for robust and predictable results.
You should immediately stop and ask questions if you cannot fully define a sketch.
I suspect that something like one of the two examples is the technique that you should have used (the outside ring can be easily removed if you don't really want it (like in your original))
@laughingcreek Yes it is similar. Good catch. Always helps to have more than one example.
Your model has a spline that is drawn around a profile. Splines do not perfectly fit curves, and this is causing some confusion in the way profiles are tracked.
The red part is a closed profile with a tiny area
The dark blue ring is a spline drawn around an existing sketch edge
