sketch selection problem
pannonrider3
pannonrider3
Hey all,
i am trying to make a simple object with sketches, but i get the weird behaviour as shown i the pictures.
This happened to me multiple times already, but didn't bother to post, but it's too annoying to ignore anymore, this time it happened, after i sketched a simple spline, but did not disappear even after i have undone it.
Can anybody tell my why this is happening?
 Thanks!
version:
2.0.10564
windows 10
jeff_strater
It looks like your pictures did not get attached.  Can you try again, or even better, post a video of what you are seeing?
Jeff Strater
Engineering Director
pannonrider3
yeah my bad, uploaded them, also deleting the non constrained circle solved it, still i don't know what it caused it in the first place tho
pannonrider3
experimenting a little more, it seems like moving a spline by its control point creates the problem
g-andresen
please show your process in a screencast as @jeff_strater  recommended
And
share the file:
File > export > save as f3d on local device > attach to next post
günther
pannonrider3
hey,
thanks for the reply
i attached the things to this post
and here is the screencast:
https://autode.sk/3mJqt6Z
jeff_strater
sorry for the delay.  Thanks for sharing the model.  While I do not see the exact same results that are in your screencast, I do see enough to have created bug FUS-90210 to track this.  Mu suspicion is that it is all the tangencies that are causing the problems, but I do not know for certain.  We will analyze the sketch and try to identify the causes and fix them.
Jeff Strater
