how to create an extruded trapezoid
wadeJ4J2S
Message 1 of 12
wadeJ4J2S
I am trying to make a solid that from the side appears to be a parallelogram in which no side is coplaner with an x, y, or z plane.  From the front view, the foremost face is a trapezoid.
I started by making a sketch of the side view, extruded it, and then tried to find a way to modify the extrusion so that the top of the extrusion was less deep (extruded not as far) as the bottom of the extrusion -- but I cannot find a way to make this last modification.
How can I accomplish this solid shape?
Replies (11)
Message 2 of 12
TrippyLighting
Perhaps a hand sketch of the final object would help.
Message 3 of 12
mango.freund
hello just use the 3d sketch and create outlines. later use areas to raise the sides. finally staple together. voila
Message 4 of 12
wadeJ4J2S
Hopefully this will help...
Message 5 of 12
wadeJ4J2S
I am a total rookie, so I need more detailed guidance please.  (I have watched some tutorials, but what you are saying still does not mean anything to me.)
Message 6 of 12
mango.freund
forget it ---- your work is too easy. is better for looking at you more videos or even give us the mass.
Message 7 of 12
wadeJ4J2S
That response does not help.  I appreciate that you are an expert at this app, so I hoped you would provide a more helpful response than "forget it -- it's too easy"!
Message 8 of 12
mango.freund
help is on the way -- please wait
Message 9 of 12
mango.freund
Message 10 of 12
TrippyLighting
Here is another approach using completely arbitrary angles and noting is parallel to any of the origin plane.
Step through the timeline to see how it is constructed.
Message 11 of 12
mango.freund
my answer was not very clever - please excuse my best regards
Message 12 of 12
wadeJ4J2S
THANK YOU!
