Sketch: Red Profile when Selected.
jeang32
jeang32
What is the meaning of the red color when the fully constrained profile is selected ? If error, the Sketch Tester indicates "Could not select points""...
Jean P.
Jean P.
You drew a  center rectangle first then added a circle mid point try adding tangent constraint on left circle  and make sure everything fully constrained. Try drawing one circle mirror it and draw two lines tangent to each circle all four spots and see. But everything must be black fully constrained. Did you stop sketch before  push pull.
davebYYPCU
Don't know why the profile is red outlined.
Is the sketch misbehaving other than that?
Nothing in the sketch shows any problem other that the red lines, if that is an actual problem.
Blue shading is Ok, lines I can see are fully constrained.
Not sure if you can extrude or not, as you are editing the sketch at the moment.
