Message 1 of 8
Sketch Offset to a point
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
As you can see in the image, I need to offset the sketch (which can be a spline) to a single point (dot dashed lines). This is different with the current offset command which is using the equidistant lines from the reference lines. This is applicable for modeling sector shaft gears which are used in automotive industry. you can this way create the involute profile in a single plane and then use the command to create the sketch in another plane instead of modeling the involute from start for the profile shift required.
