Message 1 of 8
02:25 PM
- Mute
- Permalink
- Report
I created a drawing from a 3D model and I am attempting to put a line along an axis in the derived drawing to show that some parts are aligned. I followed the procedure in https://forums.autodesk.com/t5/fusion-360-support/unable-to-display-sketch-in-drawing/td-p/8001673 to add the line in a sketch in the original model, but the line is not visible in the drawing. Just for testing, I also tried just drawing a circle in a sketch one face of the model to see if a closed curve shows up versus just a line, but that also did not show up. Just in case it it matters, the drawing is an isometric view.
Are there any special incantations required to get sketch lines to show up in a drawing?
