Sketch lines don't show on the canvas
William_Dec_45
Message 1 of 41
William_Dec_45
[Post title edited, and replies merged from duplicate thread by CGBenner 4/12/24]
I asked this earlier but I fear I posted it in the wrong place. It's been a while since I reached out. Please forgive me for repeating myself.
I've drawn a hundred or so of these where I trace around a canvas in order to 3d print a hand tool holder. But now, the sketch lines no longer show up after I click enter. I haven't changed my settings or display options in ages. So whatever is going on is doing it for some other reason. The only way I can see my sketch lines is to turn off the canvas image. I can't finish my sketch because I can't see what I've already drawn. Any help will be greatly appreciated.
Replies (40)
Message 21 of 41
laughingcreek
in your attached model, neither sketch has a closed profile.  all the sketch articles for a closed profile have to be in the same sketch.
keep in mind, when you edit a sketch, all the sketch articles from previous sketches will be shaded lighter in color to differentiate the current sketch being edited from previous sketches.   those will be harder to see thru the canvas.  I usually sett my canvas to around 10 percent.
as far as the dimensional accuracy of the image goes, an image will always be off in some way.  the pic is a guide, but measurements taken by hand rule supreme.  you can minimize distortion by taking the photo from as far away as possible and zooming in on  the object.  better yet, use an old fashioned bed scanner.
Message 22 of 41
William_Dec_45
1. "in your attached model, neither sketch has a closed profile.  all the sketch articles for a closed profile have to be in the same sketch." Honesty is the best policy, and honestly, I don't know what you mean in this paragraph. I have 3 sketch lines and all three are connected.
2. "keep in mind, when you edit a sketch, all the sketch articles from previous sketches will be shaded lighter in color to differentiate the current sketch being edited from previous sketches.   those will be harder to see thru the canvas.  I usually sett my canvas to around 10 percent."  Oddly the third line that forms the loop is black while the other two are blue. I have never noticed a difference in fresh sketch lines (the blue ones) and previous lines.
3. "as far as the dimensional accuracy of the image goes, an image will always be off in some way."  I've used flatbed scanners and cameras. The camera shots are usually much better. With regard to dimensional accuracy, I have found the drawings to be remarkable accurate. Assuming the picture is clean and flat and calibrated, the sketch produce a perfectly fitting drawer organizing if one is willing to take the time to follow the outline of the image, just my experience.
Message 23 of 41
carlweitman50
i will be back in a couple of minutes with a new design. Can you link your design in a reply to this message. can you tell me exactly what you are trying to 3d print or design
Message 24 of 41
William_Dec_45
Link and photo attached. Thank you. I appreciate your time.
Message 25 of 41
carlweitman50
what are you trying to make?
Message 26 of 41
laughingcreek
@William_Dec_45 wrote:...I turned off the canvas and connected the sketch lines to see if the inside would turn blue for extruding. Nope. ...
screen shot with only sketch1 visible.  no blue profile because you haven't enclosed an area with sketch articles-
screen shot with only sketch2 visible.  no blue profile because you haven't enclosed an area with sketch articles-
both sketches visible.   no blue profile because the sketch articles that enclose the area are in different sketches-
Message 27 of 41
carlweitman50
what is he trying to make?
Message 28 of 41
William_Dec_45
A tool chest tool organizer. I've already made many of them without a hitch.
Message 29 of 41
carlweitman50
I would just make a rectangular block around it, do you really want that design or is it ok to be like this?
Message 30 of 41
William_Dec_45
A tool box organizer. I make them frequently, hundreds.
Message 31 of 41
William_Dec_45
A third line connects the two other sketches to form a loop. You may not
see it, but I drew it in.
Message 32 of 41
carlweitman50
yes but i would make a rectangular block around it. Do you really want that design? are the dimensions on the picture correct to what you want to make in real life.
Please answer all the questions for me to correctly help you
Message 33 of 41
William_Dec_45
Rectangular block? Not with Fusion 360. Maybe with SketchUp.
Message 34 of 41
carlweitman50
a box to put the tool in. If you are hanging it on the wall, then you can just use a hook where you can hang the pliers on.
Message 35 of 41
William_Dec_45
"yes but i would make a rectangular block around it. Do you really want
make in real life. Please answer all the questions for me to correctly help
you"
I'm sorry. I thought I was answering all questions. Yes, I do want this
design. And the dimensions should be correct because I used the calibration
tool. I do this all the time.
Message 36 of 41
carlweitman50
I just dont understand what the problem is.
Message 37 of 41
William_Dec_45
Sure, that would work. But Fusion can make a custom holder. I do it all the
time.
Message 38 of 41
laughingcreek
not in the model you uploaded.  everything you have in that model I show in the screen shots.  can you take a screen shot showing just one sketch visible AND having a closed loop?
Message 39 of 41
carlweitman50
so the problem is that the pliers do not correctly fit into the tool holder.
Message 40 of 41
William_Dec_45
It's working normally again. I've probably done something wrong. Sorry for
all your trouble.
