Aligning Drawing Template with Paper
annisa_nuramalina
annisa_nuramalina
Hi guys, I currently facing some trouble in custom template for drawing. I created a new template and adjusting it according to my preferences, then when I go to my design and generate a new drawing using said template, there is no trouble at all for the first sheet, however when I add a new sheet, the said template do not aligned with the paper. Any idea how to fix this? or is there any step I missed?
ClintBrown3D
Easy fix!
In Fusion the drawing border and title block are separate items. You have included the border in the title block, which is absolutely fine.
The anchor point (0,0) for the title block should be the bottom right of the title block. Your current point is the bottom of the border.
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
CGBenner
Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
annisa_nuramalina
Oh I see. it's all set, thank you for your help! 🙂
