- Mute
- Permalink
- Report
I'm sure this is trivially easy to fix (or else I did it in a way that it isn't) but I can't see how.
The shape is an ellipse (I drew 2 circles, connected by lines top and bottom). with a rectangle through the middle. Then I extruded to 3mm, filletted all the edges, and slapped an SVG on the face (I guess I created it as a new sketch). The SVG is too high and I'd like to move it down a tiny bit. But the sketch is locked and I'm not clear what's constraining the SVG.
This screen capture shows just the one sketch and all the green lines are actually locked, I just showed one in black because I also don't understand what the purple lines mean in Photobooth environment.
Any hints on how to fix this would be appreciated.
Thanks.
=andrew
