Hi there,
I'm creating a know for my Behringer X-Touch controller..using this video to help:
https://www.youtube.com/watch?v=L-BHRdHFmdg
But I'm stuck on something I know is very simple..I just don't know how to do it.
I am going to cut a loft from a bottom 1mm circle up to a top 1mm circle...that part will be fine...but I only want this to start from 5mm up...not from the base circle.
I already have an extruded section 5mm up but I can't for the life of me figure out how to draw a circle on that 5mm up extrusion. I tried creating an offset plane 5mm up..but then when I go to paste...it doesn't paste into the same spot..so it isn't centred.
I also tried creating a sketch on the 5mm up extruded section...but I can't click on that face...I can only click on the edge..but then I can't draw a sketch there.
Could someone please explain how I get my 1mm sketch circle onto the 5mm up section please. Thank you!
Here is a picture that explains my confusion!
