Sketch elements don't move using move/copy command
mcjj29909
mcjj29909
As you can see I followed what I believe to be the proper procedure but my sketch elements won't move.
Please see attached file link and attached screencast
https://a360.co/2DeABjR
TheCADWhisperer
Are there any blue lines?
Are there any white dots?
Are there any missing Horizontal or Vertical constraints?
Are there any missing dimensions?
Are there any dimensions?
Have you posted your question in the correct forum?
mcjj29909
Are there any blue lines? Yes
Are there any white dots? Yes
Are there any missing Horizontal or Vertical constraints? I removed all from the elements to be moved thinking is might be the problem
Are there any missing dimensions? I removed all from the elements to be moved thinking is might
Are there any dimensions? I removed all from the elements to be moved thinking is might
jeff_strater
A couple of things here:
  1. you have geometry dimensioned to the origin
  2. if you don't explicitly de-select the origin, it will try to move that, which is fixed
In sketch move, if any fully fixed geometry is selected, nothing will move.  See the screencast below.  If you delete the dimensions to the origin, and de-select the origin, the sketch will move:
Jeff Strater
Engineering Director
mcjj29909
Thank you for the help.
