Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Sketch Dimensions Issues
3 REPLIES 3
VGBenjamin
112 Views, 3 Replies
In the attached desigh I had a parameter "Longeur" who was set to 80 mm and it was ok but now that I want to set it to 73 I have a list of errors:
I guess that it is because constraint prevent this change but I have no ideas how I could find and fix this issue.
Could you explain how to investigate this kind of problem?
3 REPLIES 3
HughesTooling
in reply to: VGBenjamin
Your rectangle is set to Fixed so can not be resized. If you unfix it will resize but you really should constrain one corner to the origin either with dimensions or a coincident constraint.
Green colour indicates lines are Fixed.
Mark Hughes
Owner, Hughes Tooling
HughesTooling
Another thing to avoid is lines on top of lines like this. It can cause problems with calculating profiles.
Also you seem to have a problem after the part is unfixed and resizes.
Mark Hughes
VGBenjamin
Indeed I am stupid I forgot that I had fix it. I didn't have the good reflexes yet.
About the lines over lines thank you for the advise I will avoid it.
Technology Administrators
