- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I can hardly manage to post such a simple question, but just can't solve it by my self or find a solution online.
I just bite the sour apple and expose my level of "knowledge" in Fusion 360
How do drive positions of sketch objects based on other objects? I'll add a simple sketch to show what I need
I want to ensure that the 2nd sketch, circle (hole) moves when I change the dimension of the the first, in both X and Y.
If change 50mm to 60mm I only manage to move the first. I don't want to solve this by just adding a dimension for the 2nd hole add set that to 50 as this is just to explain my problem (my real sketch will have 40-50 holes all in relation to each other and the original position of the first circle). If that made sense.
I apologize for the low level of question, but just can't mange to solve it
I will add more problems, when looking at the second screenshot , you notice that I have the same measurements in several places. Instead of defining each individually I just want to "connect" all the circles (holes) that has the same measurement to one number, so if I need to change the distance, they will all move (one value, multiple connections).
Additional question, Can you also define the diameter to be equal, connected, to one circle, so if you change 2,5 to for example 3, they all change width?
