rotate solid object
rotate solid object
rotate solid object
how do i select the axis? i try to select an edge but cant select anything. can i just tell it "x axis"?
this is an imported stl file. i can do this on object created in 360. the stl is a simple block with pockets and holes.
thanks
davebYYPCU
How are you asking Fusion to do the rotate?
Move tool, doesn't need the axis selected.  It will rotate around the pivot point of the triad.
Might help...
huszak.marcell
If you want to rotate it around a specific axis, there is option for that in the pop up menu of the move command 🙂
Student Expert
Student In Industrial Design Engineering
using axis you can rotate the body. and using right click you can get the rotate symbol to rotate the body.
