Sketch dimension doesn't update right
SaeedHamza
Advisor Advisor
SaeedHamza
This is a sketch of a user who posted in the forums on how to define it, I created the sketch and it was fully defined, but I noticed something when I was editing the dimensions ...
If you take a look at the attached video, you'll notice that the dimension I'm editing fail to edit when I set the value from 50 to 70, and works fine when I go 50 to 60 then to 70, so when going up, it needs lower values to work, I even tried going from 50 to 100 directly and it failed, but going 50 to 60 to 70 to 80 to 90 to 100 worked! In other words, I had to edit it 5 times to get it to 100, although going down in value worked fine so going back from 100 to 50 worked directly ...
Pretty odd ...
.f3d file attached
Saeed Hamza
TheCADWhisperer
@SaeedHamza
jhackney1972
The file is attached to the original post at the VERY bottom.
John Hackney, Retired
TheCADWhisperer
@jhackney1972
@SaeedHamza
Yes, I see it now.
Somehow I missed it earlier.
TheCADWhisperer
@SaeedHamza
First thing I noticed is unconstrained points.
When dragged - I see this extra arc...
SaeedHamza
That's another stgrange behaviour, and an interseting one to be honest!
That arc only appears when dragging the line all the way to the other side, it's as if the line length went to 0 and somehow became an arc ...
not to mention that one of the mirrored lines is not defined anymore :
Also, in the arc situation, one of the mirror lines is acting the right way, and the other one is going in a weird angle ...
A very strange behaviours.
Saeed Hamza
