HOPLESS ! - Simple import from AUTODESK Inventor fails
Cris-Ideas
Advisor Advisor
Cris-Ideas
I need to collaborate with company that uses Fusion. I my self am Inventor user.
I tried to upload assembly from inventor in to Fusion.
Total Failure!!! Parts are randomly scattered around. Assembly does not look at all as it should.
AUTODESK HOW IS IT POSSIBLE YOU MAKE YOUR OWN SOFTWARE SO POORELUY COMPATIBILE?
THIS IS SO UNPROFESSIONAL. AND TOTALLY USELESS FOR BUSINESES.
Cris.
Cris,
https://simply.engineering
Drewpan
I can see you are obviously frustrated. We all get like that sometimes.
How about uploading the file and giving us a screenshot of what the problem is with a bit of an explanation?
We might be able to actually help you. There are a bunch of genuine Experts here and if it is something wrong
with Fusion they can help. If it is something wrong with Inventor they can help. If it is just one of those annoying
issues because you are not familiar with the software they can help.
Before they can help, they need to know the actual problem.
Cheers
Andrew
Cris-Ideas
The problem with that is I am not allowed to share this information publicly.
Cris,
TheCADWhisperer
@Cris-Ideas
Make up a simple dummy assembly that exhibits the same behavior and Attach here.
