Sketch dependency confusion, simple extrusion breaking
ABukowski
ABukowski
Apologies - I've somehow managed to get it working without falling over after a few closes and re-opens!
Hi, I hope someone may be able to help with a newbie question.
It's my first time using Fusion, and I've not used any CAD for a long time.
I knocked together a strainer for a test 3D print, and the dimensions were slightly off by about 1mm, so I wanted to go back and edit the original sketch diameter to make the change. However, when I edit the original sketch all my other history becomes disabled with no way of turning it back on, even the first step of simply extruding the sketch upwards - this stays the same even if I revert to the original dimensions.
Only if I Ctrl-Z back to the original will my history re-appear.
I can edit other parts of the timeline without any problems, and I understand that it could cause issues further down the timeline, but I'm struggling to understand why the first step of extruding the basic sketch upwards becomes unusable?
Many thanks
g-andresen
Hi.
what sketch and what diameter are you talking about?
günther
ABukowski
It was the original 54mm sketch - for some reason whenever I edited it the whole history dependencies would become unusable.
A couple of restarts later though it was working fine - I jumped too quickly to asking the question. Seems it was a bit of a glitch with Fusion on my end.
g-andresen
I got a little dizzy trying to understand your design.
That's why I recreated it and presented the process in time lapse in the screencast.
In the file you can follow the individual steps and make desired changes with some parameters.
günther
