Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Sketch - convert curves to splines
6 REPLIES 6
rodYPDRG
797 Views, 6 Replies
I have projected an imported shape to a sketch and the curves are developed as lots and lots of curves.
This has made manipulation of the shape (moving) and cut and pasting very time consuming and difficult
Is there any way to easily convert these curves to splines or similar?
6 REPLIES 6
laughingcreek
in reply to: rodYPDRG
There's not an automated sketch tool that will do it, but these don't look particularly complex.  shouldn't be hard to do manually.  post the file if you need help (export as a .f3d from the file menu).
rodYPDRG
in reply to: laughingcreek
Thanks for that... Manual it is
chrisplyler
Do those even need to be splines? Looks to me like they might just be arcs.
rodYPDRG
in reply to: chrisplyler
Yes They could be arcs...
etfrench
Easy way is:
  • Extrude the shape.
  • Create Mesh (Select the previously created body).
  • Create Mesh Section Sketch.
  • Edit the sketch.
  • Fit Curves to Mesh Section.
ETFrench
chrisplyler
Well...if they SHOULD be arcs - that is to say that they have a constant radius at any point along them - then make them arcs. Don't try to use a spline for something that is an arc.
Technology Administrators
