Simulations Fail. Every time.
jamesf2SRYX
jamesf2SRYX
Hi All
Im having trouble with simulations.  I wanted to try the non linear solver.  The designs i was doing constantly failed.  So i watched one of Lars's videos and copied his bracket, just to get an idea of the non linear situation.
But, i cant get it to solve.  Even on ordinary static.  In fact anything i do always fails with "There is an unknown error and there are no results available"....
I must have fiddled with something as everything fails.  Any ideas?
Thanks.
https://a360.co/3sk6cql
In fact i just did a really simple one and even this fails...
https://a360.co/3Dqullh
Posted the same question to the wrong board just before.  Sorry about that.
rushabhthakkar_910
Was able to solve your Study..!!
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
rushabhthakkar_910
Results for the second one..!!
Thanks and Regards,
Rushabh Thakkar.
CGBenner
@jamesf2SRYX
Hi James,
Maybe you could share a little of what workflow you tried so that @rushabhthakkar_910 could compare it to what he did that got the results, and help you work through it.
Do you remember where you posted this earlier that was in the wrong location?  I can go clean it out for you.
Found it.
Thanks!!
Chris Benner
jamesf2SRYX
Hi All,
Today its all working again.  Exactly the same settings, didnt change anything.  Not sure what was going on.
Maybe it was my internet connection or something.   Anyway, i can do the simple models now all ok.
However, im back to my singularity issues with the actual model im wanting to do.  Will probably post some questions on that later.
Thanks guys for looking into this.  Not sure what was going on.
CGBenner
@jamesf2SRYX
I'm glad you got it working.  It can be frustrating when it fails on Monday and works on Tuesday, and you KNOW you didn't change anything.  😒
Chris Benner
