Simulation - Specify a Deflection
neljoshua
Advisor Advisor
neljoshua
Is it possible to specify a deflection in a simulation rather than a load?  I have a component that I need to deflect a certain amount and I would like to know how much force it takes to do that.
I realize that I could adjust the force and run the simulation a few times.  The issue that I have is that the simulation takes a long time to run (more than an hour).
__
If this post answered your question, please select "Mark as Solution" in order to help others who may have the same (or a similar) question.
Lenovo Thinkpad P1, 2.70 GHz Intel Xeon, 32.0 GB, Windows 10 Pro
JDMather
Do a prescribed displacement and the retrieve the Reaction Force.
neljoshua
@JDMather,
Thanks for the tip.  Unfortunately I do not know how to do that.  I found an article stating that one could right-click and select "add" from the menu, but this option does not appear when I right-click.
Guess I missed the screenshot.  I will give it a try.
__
neljoshua
@JDMather,
Ok, I got it to solve.
Thanks a ton!
__
