simulation solver error
alan.mond
alan.mond
I am trying to run a simple simulation to determine the best extruded aluminum profile for a 22N camera on a boat.  I am coming across this error
I am trying to simulate is a 72" pole attached to the back of a boat.  This is the profile.
Overview of the entire simulated assembly (bonded):
Pavel_Holecek
Hello Alan,
it looks like that there is probably a problem with  camera body (voxel mesh) could you share your design? Without mode is really difficult to identify the Error.
Thank you
Regards
Pavel Holecek
Autodesk QA team
alan.mond
Absolutely, the file is attached.  Thanks!
alan.mond
Ok, I was able to solve it with Aaron Magnin's help.  The trouble was being caused by the weird profile shape.  So he suggested to re-generate the mesh using 4% of the model volume under mesh settings and that worked!
