Simulation of Uniform internal pressure of a pressure vessel with threaded cap`
11:00 PM
I'm trying to run FEA on this pressure vessel where the cap is held down with a threaded ring. How can I simplify this to get accurate results. I tried applying the pressure at the top of the lower cap and on the walls, same pressure. I also added a constraint on the outer wall and upper surface of the threaded ring. Is this correct? I get results that say it passe the test though I am skeptical since the threads show no gradient in safety factor. Does this make sense?
