Simulation Mesh Size Absolute
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a "board" which dimensions are 110 x 300 x 3cm. I am trying to generate a mesh fit for analysis.
When using Absolute size.
a. If the size setting is set to 10mm, I get 6 tetrahedral elements in the thickness section.
b. If the size setting is set to 12mm, I get 2 tetrahedral elements in the thickness section
I was expecting 4 ? In fact I am unable to find the absolute Size thickness settings which would lead to 4 elements in the section....
Can you pls explain what is actually happening ?
2. From reading I understand to get meaningfull results from this analysis of deformation of force/load applied in the direction of the thin section, in parabolic element order, I would need at least 6nodes.
This is would be achieved by the 4tetrahedral, correct ?
6 tetrahedral in a section is slow to solve and would like to avoid it as a starting point for an adaptive mesh analysis which takes too long.
Thank,
Jean P.
