Simulation: How to apply a load on a specific area of a face.
sylvain_boyer6TGNB
sylvain_boyer6TGNB
I would like to run a static simulation where I have a Y constraint (vertical direction) on a partial area of the bottom face of my part, in the simulation module=> Simplify,  I could create a sketch to model the boundary. There is no option to create a face.
When I exit the the simplify I cannot, the sketch is not visible and I cannot select where my boundary condition should be applied to.
TheCADWhisperer
https://www.youtube.com/watch?v=-EdgxXZV-ZI
@3:25
or you could define the area in Simplify...
Drewpan
@TheCADWhisperer
Howdy stranger! Nice to have you visiting or back with us.
Cheers
Andrew
henderh
Hi @sylvain_boyer6TGNB,
The Limit Target option can be used to restrict the load zone to a smaller circular area. However, the option is offered only for the Angle and Vector direction types.
If you require a non-circular area, or multiple locations of a limited target, splitting the face in Simplify is the way to go (as @TheCADWhisperer shows in the video).
Hope this helps,
Hugh Henderson
QA Engineer (Fusion Simulation)
sylvain_boyer6TGNB
At the end I made a slight 0.1mm extrusion in the simplify model the boundary where the constraint is applied, and let the meshing tool do its job ignoring small features. I find it odd we cannot create "profile" that does not need to be extruded.
