SImulation - Event Simulation
bespel
bespel
I presume is it now possibile to do something like that...
https://www.youtube.com/watch?v=jAkNuQAvK3g&t=19s
Cn you help us with an example or with setting?
because I can't reach this results.
thanks
John_Holtz
Autodesk Support
Autodesk Support
Hi @bespel
Fusion does not have shell elements. Analyzing a thin cylinder using solid elements and getting accurate results is not possible with Fusion simulation.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
bespel
@John_Holtz
Thanks.,
I know that there are no shell tool, but normal analysis are possibile even if there are thin wall (4 or 5 mm)
Looks here
https://www.youtube.com/watch?v=spDsbb_ZoHQ
I just want to do this
John_Holtz
Autodesk Support
Autodesk Support
Hi @bespel
I agree that you can analyze anything that you can setup and run within 12 hours (the limit for an event simulation). You could even model the crushing (buckling) of a thin cylinder. But if you want accurate results, you cannot use solid elements for a thin-wall part.
I edited my original post to clarify that the results will not be accurate when modeling thin parts with solid elements. If accuracy is not important, then you can run the analysis.
John Holtz, P.E.
Autodesk, Inc.
bespel
Nice.
Now we are at the point.
What setting do you suggest to reduce the 12 h and get close to a good results?
The online guide it's not clear at all.
Inertia..no inertia...number of steps...time of the total event...
Thanks!
John_Holtz
Autodesk Support
Autodesk Support
This article does a fair job of describing the relationship between the event simulation runtime and the input. See "This Event Simulation model will exceed the allocated Tech Preview run time limit of 12 hours" in F.... Here are some of my thoughts (and clarifications) on how to reduce the runtime.
  1. The time step size is fixed by the equations used to solve the analysis. You cannot make the time step size larger to reduce the runtime. (At least you cannot change the time step size directly.) To get to a certain event duration requires X steps, where X = the duration/time steps size. X number of steps require a specific time to solve, and that is how the software predicts if the total time will be greater than 12 hours. Therefore, you can only reduce the duration of the event to reduce the runtime. For example, if simulating a drop-test, move the model close to the floor. There is no need to simulate the 6 foot (2 meter) drop. For example, if applying a force or enforced motion, apply the load over 0.01 seconds instead of 1 second. (This changes the kinetic energy, but the kinetic energy may be small compared to the total energy depending on the analysis. In other words, the speed of applying the load may not have a drastic effect in some models.)
  2. The number of steps that you specify under the Setup is the number of results that are saved. The analysis will still calculate X steps, but only save the number that you specify. I suspect there is a small difference between saving 10 steps versus 100 steps when it comes to the total runtime.
  3. Do not use the quasi-static (no inertia) if trying to reduce the runtime. The quasi-static does the same analysis as the dynamic, but it changes the total duration to minimize the kinetic energy. Therefore, the quasi-static analysis may run the analysis 2, 3, or 4 times, with longer durations for each cycle.
  4. Increase the smallest mesh size. The time step size of the analysis as fixed by the solver is related to the smallest element in the mesh. If you can eliminate fillets and rounded corners, or adjust the mesh on those features so that they are the same size as the rest of the model, then the analysis time step size will be larger.
Although those factors will reduce the runtime, they do not improve the accuracy. It does not change the limitation that 1 solid element through the thickness of a thin wall is not enough to capture the stress gradient from the inside to the outside (especially in the buckling example where the bending is about multiple axes).
The better solution is to use Inventor Nastran (version 2021) where you can use shell elements to perform the analysis.
John Holtz, P.E.
Autodesk, Inc.
bespel
tahnk you @John_Holtz
This ability is sponsored in the What's new page.
https://www.autodesk.com/products/fusion-360/blog/whats-new-in-fusion-360-event-simulation-analysis-...
If the results are no correct, why is it sponsored?
It looks as a thin wall.
I just want to replicate this, can you suggest me the setting or provide just a similar sample?
Thanks!
