Simulation Error when creating Mesh with simple component
aquamoon
aquamoon
Hello
I get a self intersection and face interior meshing error with the attached file. The component is a simple one.
John_Holtz
Autodesk Support
Autodesk Support
Hi @aquamoon
There is something about the splines that is causing a problem. It could be due to their length or the area of the face. I was able to mesh the model with a mesh size of 20 mm, and it shows some elements that are abnormally small and large.
Large and small elements in the mesh.Large and small elements in the mesh.
When I see such problems (in other software), I usually split the faces to create smaller arcs/splines and areas. For example, I used the Simplify environment to split the faces into a number of smaller regions. (Split all 4 faces: the front, back, inside, and outside surfaces.) A mesh size of 20 mm worked with just a few regions of slightly smaller mesh.
Let me know if you encounter any other problems.
John Holtz, P.E.
Global Product Support
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
