To all;
The 'CADWhisperer' suggested I post on this board of the forum.
I have been using the simulation tool for the last 10 months now, and in particular the static stress tool. All of the structures I have simulated have included tubes of various lengths and wall thicknesses. In almost all cases these tubes intersected each other. I modeled holes or copes in each case. Meshing those rarely failed. Running the solver worked reliably.
This time I am modelling an engine mount made up of tubes as well. The tubes are all carefully cut and coped in the model. A few times it passed the meshing stage and the solver had no problem solving the system. However, most of the time the meshing stage fails. It never even gets to the point where I can run the solver.
The results I got from the few times things worked as expected. The results agreed well with my paper calculations.
Therefore; it seems that the solver is capable of solving this structure. It is the meshing step that fails. At the moment I'm looking at a "Meshing Error! Phase: Surface meshing. Description: Face interior" message.
Any help would be greatly appreciated.
