How can one simulate the thermal transfer from a milling tool carbide insert at 750 degrees C into the base material? We can assume that 60% of the total thermal energy generated is removed by the very hot chips as they plasticize, ride up the tool and break off of the rotating tool.
We can furhter assume that of the remaining thermal energy (100% - 60%), an additional 15% is transfered through the tool body, tool spindle and then out through the spindle liquid coolant at 96 degree F.
How can we determine how much residual thermal energy not carried away by chips or spindel coolnat is transfered into the base material part that is not machined away?
Hi @Anonymous. Welcome to Fusion.
Machining is a transient process (the tool moves), but Fusion's thermal analysis is limited to steady state (all heat loads and cooling are constant for an infinite length of time). I do not have any suggestions on how you would do a thermal analysis of this with Fusion.
Maybe someone else with experience in machining will have some other suggestions.
John,
Thank you for the reply back and for clarifing what Fusion can do. Hypothically, if I wanted to attempt this transient type of simulation, what Autodesk software product would I need to begin to consider?
If you are not comfortable making a recomandation, would be able to forward me to the most appropriate resouce so I could follow up. Thank you.
Bob Jensen
