Simple question: How do I align sketch objects to midpoints of lines
autodesk
autodesk
I am making a sketch with something like a circle in the middle of a rectangle, but I can't figure out how to do this with constraits.  Can someone answer this?
Thanks.
schneik-adsk
I would draw a line from one corner of the rectangle to another, then select this line and from the context menu make it construction. Next I would start the constraint command and select the line and the center-point of the circle, and thens elect the midpoint command. this would make the circle at the center of the rectangle. Was this what you were looking for? Posting a picture might help?
Kevin Schneider
Macro.Liu_Autodesk
If you just want to draw a circle in the middle of a rectangle, then the way Kevin provided should help. Another possible way for your reference:
1. Invoke Center Diameter Circle command and hover the mouse over the mid point of one edge of the rectangle - MidPoint shows, and then move the mouse to the center - Reference line shows.
2. Continue to move the mouse to the mid point of the other edge - Midpoint shows. And move the mouse towards the center - Reference line shows
3. When the mouse is at the center, two Reference line will show - Now click to specify the center and draw the circle.
Hope that's what you want. If not, please show us snapshot.
Macro Liu (Fusion 360 QA)
techboycr
Observer
Observer
Indeed!! this is the solution.
It works like a charm.
