Show ONLY sketch that is being edited (Edit in Place, Edit Sketch)
tookemtoni
tookemtoni
While performing Edit Sketch within a Edit in Place session and I don't know why all the sketches show when I choose one sketch to edit.  It is hard to Select the correct "Sketch Line" for example.
See video demo:
etfrench
Just turn off the visibility of the sketches, bodies, and components that you don't want to see.
ETFrench
jeff_strater
This is done on purpose.  There are commands in sketch (Project, Intersect, etc) that allow you to reference a sketch element in a different sketch.  As @etfrench says, if you don't like this, you have full control of the visibility of other sketches.
Jeff Strater
Engineering Director
laughingcreek
after manually projecting what I will need for the sketch (I have all the auto project stuff OFF) i will use "isolate component" to at least get visibility on most of the model turned off.
@jeff_strater - isolate sketch might be nice.
