force constraints on corners of two components
destinyMYUA8
Message 1 of 9
destinyMYUA8
I'm so new that I know I'm ignorant of the simplest things.
So...I've created 2 component bodies that I want to have tied together at a coincident point.
The attached images show my problem.
thanks!
Replies (8)
Message 2 of 9
aliobidi
Hi ,
use move point to point  .. see attached Pic
Message 3 of 9
TheCADWhisperer
Message 4 of 9
davebYYPCU
Use Joint, and do not use Move.
Joint will hold the position, Move will not.
Joints have degrees of freedom for animation, Move does not.
After using a Move / Capture Position without a Joint, the Component is still unlocked and free to be moved again, click drag accident or intentional.
Might help....
Message 5 of 9
laughingcreek
without seeing the file, can only give general answers.
and need some clarification.  do you have 2 separate COMPONETS, each with a body in them, or do you just have 2 seperate bodies?
components are positioned by either building them  "in place" (not what you've appeared to have done) or by using joints.  no other ways.  DO NOT USE MOVE OR ALLIGN.  it'd not parametric for component moves, and requires a position capture to keep it in place.  either reason is a good enough reason to not use move or allign.
Message 6 of 9
g-andresen
get familiar with joints
günther
Message 7 of 9
destinyMYUA8
Thanks for the reply.
I think you may have hit the nail...
here's the google doc link to the file
https://drive.google.com/file/d/1aZVe3gKtkXgx4uSgQK-U44F0vIwuu9O0/view?usp=share_link
Of course I am hacking at it pretty hard, but the previous version was 20MB, and this one is tiny.  I deleted an entire timeline on one component and started over, and this doesn't have the spiral columns, but.... Is that weird?
Message 8 of 9
destinyMYUA8
Super, thanks so much.
You pulled some wool off my eyes!
Message 9 of 9
destinyMYUA8
CADwhisperer,
The general consensus appears to be that I need to be using joints.
Here's the google dods linkd:
thanks so much!!!!!!
mark
