- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hopefully the title is fairly descriptive here, but I'm somewhat confused as to when I really need a bunch of bodies and when I really need a bunch of components.
Let's say I'm designing something to be 3D printed. The design has no moving parts (hence no joints), but each part is mounted to the other part via bolts. Each part is therefore separate, but not completely independent as the geometry of all parts are closely related, if not completely shared (e.g. hole size and position in part A must match that in part B).
It's possible to place a sketch plane for component X onto component Y, utilising the geometry of Y to create X, but that seems odd because I feel that a component should be something self-contained, and independent of another component (like a gear, a spring or a bushing) Having said that, the whole design is made of individual parts, which are ultimately going to be assembled, so maybe I need an assembly of components.
So, you see the dilemma, or maybe that's just me. Any thoughts are greatly appreciated.
Thanks! - Tom
