Shortcut for Look at
Message 1 of 44
I cannot find a shortcut key for 'look at'.  I wish to set one of my extra mouse buttons to this, as it is how I design when using SolidWorks.
If I cannot set that, how do you guys design? Just dragging your mouse allll the over to that button every time you need to be normal to an angled face?
Replies (43)
Message 21 of 44
yaniv2YDRE
Observer
Observer
@admin
How difficult is it to make "look at" shortcut?
Watching this thread since 2015...
Message 22 of 44
matt5N72A
I never even got the dirty hacks to work (see message 16). Matt.
Message 23 of 44
aaron7P42J
Surprised this hasn't been posted yet. As a former SW user, this made my transition to F360 a lot easier. "Normal To" was ingrained in my work flow and it was only natural "Look At" would be as well.
Go to File.
View >
Show Text Commands
Type or Copy and Paste - hotkey.dialog LookAtCommand
Your window will pop open and you can assign any hot key to "Look At".
I use the Space bar.
Message 24 of 44
mbanksB487R
This is what I get:
"There is no command LookAtCommand. Use ? to get help on available commands"
Message 25 of 44
aaron7P42J
Oh shoot, my mistake, copy and paste the following.
hotkey.dialog lookatcommand
Message 26 of 44
mbanksB487R
IT WORKED!
My only complaint is that I can't use PgUp for hotkeys, but I don't care. This has been a pain in my butt for YEARS.
You're my hero, thank you.
Message 27 of 44
gil_vit
Thanks a lot!
This will surely help using Fusion as a former SW user.
Message 28 of 44
matt5N72A
I would have loved for this to have worked, but still no luck unfortunately.
Initially I tried adding the hot key via the Space Mouse, but same behaviour as before in that it brings up the Offset command.
Then in the name of science I tried just assigning space bar using the text command, but it does absolutely nothing.
Message 29 of 44
mbanksB487R
Did you get the assign hotkey dialogue?
Message 30 of 44
matt5N72A
Yes.
I don't like the look of that 'InvalidCommand' part thought.
This is after pasting in "HotKey.Dialog lookatcommand" to TEXT COMMANDS.
Message 31 of 44
matt5N72A
OK so it's case sensitive if anybody else is struggling....
Message 32 of 44
matt5N72A
...and whichever key you assign can be used by your Space Mouse. Easy when you know how!
Message 33 of 44
aaron7P42J
Weird that it's now case sensitive. I literally copy and pasted  from my dialog box. Wonder if the last update broke this.
I'll edit my OP in case anyone stumbles in here down the road.
Thanks for the heads up.
Message 34 of 44
matt5N72A
Are you on a Mac by any chance?
My software was wildly out of date when I first tried it, and I've done two updates since thinking that might have been the reason why it wasn't working, but the behaviour did not change, so I don't think it's anything to do with updates, at least, not on my setup.
Message 35 of 44
aaron7P42J
Nope, PC.
I'm not sure why it would matter if it was case sensitive or not but at least we have a solution for something so easy to fix.
I'm not sure how connected Autodesk is with their users, but this would improve workflow by 10 fold.
Also, can we please have small icons or the option to have small icons? I hate the drop down menus, stop hiding everything. let me load it all up.
Message 36 of 44
Jillian.Alaimo
Finally found this! It works wondefully. Also works lovely for FindInBrowser which saves me lots of right clicks. Might be a new feature? I just wish I had a list of what things are called, I lucked out they used the LookAt example and FindInBrowser I guessed correctly.  https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Customizing-hidden...
Message 37 of 44
jrychter
Revisiting this thread in 2024 and it's every bit as amusing at sad at the same time as when originally posted.
Message 38 of 44
murat_ozdenG
Community Visitor
Community Visitor
Hi.
Just go and download " X-mouse button control ". and then change one of the buttons on your mouse. I did it on middle mouse. It doesnt allow you on keyboard but maybe you can find similar software for keyboard as well.
you can see on the picture I shared. "" Middle button=(pressed mode) sloo{RETURN} ""  just simulated "S" on fusion and write "loo" then press Enter.
Message 39 of 44
sionNLC37
Community Visitor
Community Visitor
end of 2025 and still no normal to/look at? Can't believe this.
Message 40 of 44
aaron7P42J
and in 2025 with the September update, they just unassigned space bar look at because they made spacebar "last command" which is completely useless.
