Shelling issue
Shelling issue
BilalHussain5008
Message 1 of 14
Shelling issue
BilalHussain5008
I can't seem to shell this model any thicker than 0.3mm
I get the "can't offset selected faces". I've tried the "splitting body" and "scale techniques", but somewhere along the process, I get the same message.
I've even tried Powershape and Plasticity...
Replies (13)
Message 2 of 14
laughingcreek
can you export your model as an .f3d and attach that instead of the step file?
Message 3 of 14
wersy
Before you get lost in the details. Is it supposed to fly?
If so, forget the airfoil. This will give you a strong negative pitch moment that cannot be compensated by the elevators.
In addition, the elevators cannot move upwards in the way you have designed it.
Message 4 of 14
BilalHussain5008
Hi wersy.
The elevators need to be moved back by 5mm to create a gap, similar to that of a slotted flap. I've conducted some basic research, which suggests that using the MH60 airfoil and placing the center of gravity towards the front will result in a flying wing.
Thanks for the thought:)
Message 5 of 14
TrippyLighting
The wall thickness in this area is too small to be shelled any larger than what you have already encountered.
Message 6 of 14
BilalHussain5008
Thanks for answering!
Here you go folks! A f3d.file
Message 7 of 14
BilalHussain5008
Hi, thank you for your response!
Maybe splitting the body into simpler sections will solve my issue. I'll give that a try!
Thank you for your time, sir.
Message 8 of 14
BilalHussain5008
This seemed to work, but I can't shell it to between .799-.804mm
Oh well, I'll use .805mm 🙂
Message 9 of 14
TrippyLighting
I think we were hoping for a .f3d file with a design timeline that shows us how the object was modeled 😉
Although if that doesn't exist, I guess the STEP file is fine, but it will require a very different workflow.
Message 10 of 14
BilalHussain5008
I managed to achieve a shell thickness of 0.8mm by splitting the body in a specific way. For future reference, if a complex geometry fails to shell, consider splitting it up.
Message 11 of 14
wersy
@BilalHussain5008  schrieb:
Hi wersy.
A gap between aileron and wing?
You know that in flight the gap must be almost airtight?
You can also take NACA0010 (if you need the thickness)  and adjust the S-stroke with elevator.
I have done this with all my deltas like this one.
https://www.thingiverse.com/thing:4981477
Message 12 of 14
BilalHussain5008
A gap between the elevators and the wing. Like in a slotted flap:)
Very impressive that you have a wing loading of 2.88kg/m2. I managed 4.9kg/m2 (RC planes have a range of 2-12kg/m2)
What were your motor output(w) and battery watt-hours? Flight duration? Pitch speed?
Message 13 of 14
wersy
About 250 watts at full throttle.
5 minutes flight time at mostly top speed (the controller has slowed down then) with 2200mAh 3S battery.
That's all I measured.
Message 14 of 14
BilalHussain5008
Can't recommend this enough! (https://rcplanes.online/calc_motor.htm) and (https://www.ecalc.ch/perfcalc.php)
Great for calculations and optimization! Finding parts. I plugged in your values and got 5.25 minutes of flight time.
