Shelling Issue on an Angle
jrobersonJE6HW
Message 1 of 8
jrobersonJE6HW
I've been trying to shell a piece but when it shell it doesn't cut the angle but makes a straight edge. Is there a work around or something to fix this issue?
Replies (7)
Message 2 of 8
jeff_strater
can you share the model here?  Cannot tell from just an image.  Thanks.
Jeff Strater
Engineering Director
Message 3 of 8
mango.freund
why do you have interruptions here? are these bodies that are not connected? that could cause the problem. greetings mango
Message 4 of 8
jrobersonJE6HW
Those aren't interuptions. Thats just the sketch being visible, as I wanted to show how I would've liked the shell to cut the piece. Which, as you can see on picture where I circled the angle being cut off and straightening instead of shelling continious angle.
Message 5 of 8
jrobersonJE6HW
Here are some pictures
Message 6 of 8
TrippyLighting
We need the model in .f3d format, not images of the model.
Message 7 of 8
jrobersonJE6HW
AH! Okay. Here you go.
Message 8 of 8
WHolzwarth
There's a small vertical face between the red face and the internal bottom.
Delete it before the last shell, and it's ok. See section below.
Walter Holzwarth
