Shell Workflow vs Inventor Shell Workflow
jgreene
jgreene
Here is a part that I was attempting to complete a similar workflow in Fusion360.
https://a360.co/3gA6xiB
Inventor workflow:
  1. Shell at .1 in remove top back surface
  2. Use additional options to specify the back face thickness to be .6 in
Fusion Workflow:
  2. Extrude back face an additional .5 so the back surface is .6 in thick
Is there a way for additional options in the shell tool or is this the best workflow substitute?
jhackney1972
I think you have one of the best workflows since the Shell command in Fusion 360 does not have a variable wall thickness option.
John Hackney, Retired
